Window Contours in OpenGL
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-12-12
07:09 PM
2023-05-26
11:12 AM
Rubia Torres
2017-12-12
07:09 PM
See attached.
I'm using AC19.
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-01 02:43 AM
2021-02-01
02:43 AM
I'm stuck on the same thing, is there any solution? Windows seem fine for me, it's the leaf contours for library "Door 23" I can't remove. Setting the object's 3d Leaf Pen to transparent or background makes it revert immediately to no. 2 of the pen set.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-15 10:56 AM
2021-02-15
10:56 AM
Dear All,
Thank you very much for your question and I am very sorry about the issue!
Unfortunately, this is a known limitation of Archicad. In 3D, each construction element will have contour lines, and these lines cannot be transparent. The only workaround I can think of is matching the pen color with the window/door surface to make them less pronounced in 3D.
Once again I am very sorry for the inconvenience! Please let me know if you have any further questions!
Best regards,
Minh
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
