I am trying to create a window that I like in GDL. I am not that familiar with GDL, however.
My goal is to make the window so that the frame of the window is the same depth as the wall thickness and the sash stays the correct static distance. The sash is easy, but the frame is not. The frame depth challenge is due to differing wall thicknesses. So if the window is inserted into a 2x4 stud wall with a total thickness of 4 1/2" the frame will adjust accordingly. Likewise with a thicker/thinner wall thickness.
In the 2D view from the GDL subtypes, hotspots can automatically appear on both the interior and exterior face of the wall. If I knew how to set the frame depth to match those hotspots I would be all set.
Can anybody please assist me?
