Window & Door Dimension Markers missing FIXED
When going into the settings dialogue of either doors or windows, the option to use Dimension Markers is completely missing from the list.
Is there a global preference I have inadvertently changed causing this?
David Maudlin
Ty:
Look at Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Window Tool > Dimensions Marker to see if it is hidden. When making a change to your Work Environment, be sure to select the Scheme and click the Redefine button to save the change.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
All corrected.
Thanks for that.
