Window and Door Opening Lines
drh64
In 16, where have they moved this setting now? It is not under Model View Options anymore.
4 REPLIES 4
Hi Daniel,
This is in the MVO ... but under the GDL Objects / Library panel. It has been there for several versions now. (Note that if you have more than one library loaded, you may likely have a separate panel for each library.)
See attached.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
drh64
Thanks Karl but what am I not seeing???
I don't have it on my window.
Do you have the full 16 library folder loaded, Daniel? Or what windows/doors are in your project if not?
The library itself generated the panel in the MVO dialog. If you have the full 14, 15 and 16 libraries loaded, for example, you would see a panel for each of those libraries. Or you should...
David Maudlin
Daniel:
In addition to the MVO option, each window and door has the option of overriding the MVO setting, under the Opening Lines panel.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
