Window and Door dimension marker
Is there a way to make the dimension marker show up in feet AND inches if using a generic window with the builder dimension marker. I have been asked to do this for a plan and i don't want to have to become unlazy and type it in there. I do however realize that i have just typed a lot more that i would have on the doors and windows but I guess it is the same as vacuuming over a string and the vacuum not picking it up so you bend, pick it up to free it from the carpet and then drop it back and vacuum it up. Anyway, if there is a solution out there, I would appreciate it very much. Thanx.
1 REPLY 1
Link
This is something we pushed hard to get into the Special Edition Library and while it's not perfect (doesn't include 0"), it is a big improvement.
You can download the SE Library from http://tr.graphisoftus.com/
Link.
