Window and Door marks on electrical plan
Hi all, is there a way to turn off window and door marks on, say, an electrical plan where those marks are not needed?
4 REPLIES 4
Steve Jepson
As Steve has shown it is controlled in the MVO settings.
You then need to 'Store As' a combination with the markers on and another with the markers off.
Then in your view settings for the electrical plan ensure the MVO combination for no markers is set.
The other MVO combination can be used for your other plan views.
Thank you very much for the reply. I'll try to make this work for my project.
The model view option 'option' is huge. After experimenting with that, I've created several 'option' views for different scenarios. Thanks Steve and Barry for pointing the way.
