Gabriel Cristea
Assign a classification to door/window labels
Hi everyone;
When activating the window and door labels using the window/door built-in dimension marker option, the labels appear to be picked up by my graphic override that marks in bright solid red anything that it finds not having an Archicad classification. I've tried to look everywhere within the door/window settings to give a classification to the label itself, but I can't seem to find this option anywhere.
The windows and doors do have the correct classification assigned to them, but this label that you can toggle on/off doesn't appear to have one, and I am not sure where I can give it one. You'd think that the label is a 2D element (such as lines, fills, etc.) and cannot have a classification assigned to it, but here it is being picked up by the graphic override.
Many thanks,
Gabriel.
Operating system used: Windows 10
Setup info provided by author
Yves
Maybe just put Element Type All Types 3D
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Lpalma
Hi. I don't think these types of 2D elements are supposed to be assigned within classifications. You could check the rules for graphical overriding so that it doesn't mark the labels, perhaps by assigning all the 3D elements in the Criteria Element type.
Lpalma
