Project data & BIM
SOLVED!
Incorrect Door Orientation being reported
JoeA
It seems a very small quantity of doors are incorrectly being scheduled as “R” by the Door Orientation property.  The problematic doors can be mirrored, flipped, replaced, and still report as “R”.  Even if the wall segment is replaced, it reports as "R". Even if a correct "L" door is syringed and injected, it will report as "R".
I am at a lost for troubleshooting the issue. We are really depending upon an accurate schedule for take-offs…
Joe A.
(ArchiCAD since 8.0)
1 ACCEPTED SOLUTION
Solution
Yves
Check that the orientation is automatic
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
2 REPLIES 2
Solution
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Thank you. Even though it is over a year later, the issue resurfaced.  It seems I missed your reply last year.
Regards,
Joe A.
