Reset orientation constrains
At some point AC started to remember the rotated orientation that was once set in the project. That is pretty useful in general but having a bad luck I managed to set two very close angles (within a minute). And now when I draw occasionally it snaps to the incorrect direction and makes me mad.
I couldn't find a way to reset that directional constrains to re-set them correctly. Is it even possible in AC21?
Eduardo Rolon
2 options, none too fast.
First one is that since AC only stores a limited set of orientations if you create new ones instead of selecting the previous ones will disappear from the list.
The other is to do a "New and Reset" to create a new File and that will remove all orientations and then you can open the previous file. For this one if before doing the N+R you have the orientation set to the one you want to keep then when you open the file again this orientation should be there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
