I can see that the option to rotate the orientation in section is unavailable, but I was only wondering if rotating the view in section is anyhow possible?
Can't figure out what you want to do but if you want to rotate a "drawing" you can rotate it after you place it inn a Layout.
If you want to rotate an object it depends on what type.
Eduardo Rolón AIA NCARB AC29 US/INT -> AC08
Mac Studio M4 Max 64GB ram, OS X 10.XX latest another Moderator
