Reset orientation in section
I can see that the option to rotate the orientation in section is unavailable, but I was only wondering if rotating the view in section is anyhow possible?
Eduardo Rolon
Can't figure out what you want to do but if you want to rotate a "drawing" you can rotate it after you place it inn a Layout.
If you want to rotate an object it depends on what type.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
DGSketcher
Legend
You can't rotate a section but you could create a Worksheet of the section and rotate that to to the required angle if that helps.
