Project data & BIM
SOLVED!
DOOR CASING FRAME DOES NOT SHOW IN SCHEME
Fabian_MENDEZ
HI, in the doors schedule, the elevation and axonometric view don't show the exterior frame with different dimensions. how can it show in the schedule?
1 ACCEPTED SOLUTION
Solution
Pedro Melo
There is no direct way in archicad to do that. Before using Library Part Maker, I used this trick: https://www.youtube.com/watch?v=SSLjSEhj4pI&t=4s
2 REPLIES 2
Solution
Pedro Melo
Fabian_MENDEZ
Thankyou very much, I will follow your advice!
Greetings from Paraguay
Setup info provided by author
