2007-06-25 01:42 PM - last edited on 2023-05-24 12:44 PM by Rubia Torres
2007-06-25 05:21 PM
2007-06-25 06:03 PM
2007-06-25 06:37 PM
2007-06-26 12:09 AM
It seems to be an execution order problem but the values of the globals cannot be used to force the values of user parameters.That's not true for all global parameters, but it is not documented. Yes and no. On www.selfgdl.com you find in section "context" for each global, in which context (either object type or script environment) the parameter is full available. This is an incomplete list, of course, but it is a beginning. AND there are globals, which are available in GLOB_CONTEXT=5, the one and only moment, when the PARAMETERS command does take affect on the local parameters.
