Hubert Wagner
GDL : Get xy coordinate of mouse click as GDL input
Hello :
How do I record the xy coordinates of a mouse click in GDL?
I want to define two point on screen and then have my sub-routine size an object and place it between these two points. e.g. the start and end points of a joist.
Start:
Select the type of GDL object
Get x1Y1 (first mouse click)
Get x2y2 (second mouse click)
(do calculation and place object)
Thanks : DW
TomWaltz
You don't need GDL for that. You can just use the 2-point object placement method.
If your overall object size uses the A and B variables, it should size perfectly to fit between the two points.
Tom Waltz
