trying to get zone to list area sf multplied by a parameter
I'm starting out with a zone tag that will put in the area surrounded by a box and the following is part of the code
if area then
n=n+1
vlen =vlen + shight
Text2 middle, -vlen, room_area
endif
I thought I'd just add some more code where xx_rsf = room_area* parameter. The problem is I cant multiply room_area by a parameter! How do I accomplish this
if show_rsf then
n=n+1
vlen =vlen + shight
Text2 middle, -vlen, xx_rsf
Thanks,
michele
5 REPLIES 5
Aussie John
You can use the somewhat confusing STR command to "convert" the erroneous string into one that will allow multiplying.
Cheers John
[/size]
John,
I think you mean the SPLIT command. That's what will extract numbers from strings. STR makes formated strings from numbers.
Frank Beister
There must be another problem in your script. ROOM_AREAin zone stamps is numeric type (real) and can be multiplicated with other numeric values and variables/parameters.
rsf_123=(room_area)*rsfmul
rsf_123 = rsf_123 + area_unit
and then further down the code:
if area then
n=n+1
vlen =vlen + shight
endif
if show_rsf then
n=n+1
vlen =vlen + shight
Text2 middle, -vlen, rsf_123
I don't get an error now that I put parenthesis around room_area before I multiplied it to the parameter rsfmul ... but my numbers are all wrong. For a 50 ft sf area the rsf_123 that is being displayed in the zone tag in 2D is 5.34192 without the sf after it. And the rsfmul parameter = 1.15. So I want the zone tag to get the sf from the zone tag then look at the parameter rsfmul and multiply it by it then display that number with SF after it in the zone tag in plan.
Such a simple task yet so tricky
Thanks for all your help,
Michele
Frank Beister
Have a look at the STR-command. You have to use the version with formatting string. It allows to output other than metric values.
Internal AC works metric only. Even if you insert a ft-value (depending of your general project settings) in an infield the parameter will immediately change it to metric.
