Window label with elevation to project zero?
Hello
I would like to script a window label that would indicate the elevation of window sill relative to project zero.
So far I have succeeded in making it work as long as the wall base is the same as the story base, like this:
str("%+1.3m",AC_GLOB_ELEVATION+GLOB_HSTORY_ELEV)
But I don't know how to make the label read the elevation of the WALL base relative to story base elevation.
Does anyone know how this could be achieved, or if it's just impossible?
17 REPLIES 17
Frank Beister
Try this one:
ac_wall_elevation or ac_glob_elevation
And there's a bug in reference height to current story of windows visible in other than home stories.
I am having no luck with ac_wall_elevation...
My string now looks like this:
str("%+1.3m",AC_GLOB_ELEVATION+GLOB_HSTORY_ELEV+AC_WALL_ELEVATION)
I have also tried adding the parameter "ac_wall_elevation" in both the label AND the window object parameters
However, when I change the wall elevation (and the window ascends and descends with the wall) the label does not change... the number shown is still as if the wall base was the same as the story base...
Maybe it doesn't matter at all because GDL is not case sensitive as far as I know, but the "GLOB_XXXXX" variables are always all UPPERCASE, the "ac_xxxxx" variables are always all lowercase.
No the case doesn't seem to matter... I tried changing it consistently to lower case - no effect. And it seems lower_case, UPPER_CASE, and Mixed_Case are used interchangeably without problems, in the objects I am trying to tweak.
But thanks anyway for the suggestion!
Really I find it hard to believe that a marker associated with a window would not be able to query the elevation of the parent wall? But maybe they didn't come to think of that when they wrote the gdl specs. Well for now I must resort to writing the value manually.
Maybe it is too many levels.
I mean, a Window knows certain variables about the Wall it is in.
A Window label knows certain variables about the Windows it is associated with.
But a Window label to know about the Wall into which its associated Window is placed: could be a limitation.
I will forward this to GS.
is this what you are looking for?
WIDO_RSIDE_SILL_HEIGHT+WALL_POSITION[3]
Frank Beister
I have lost a lot of time in finding the following bug:
"HOME_STORY, used in marker objects, always returns the home story of the wall, not of the window. A wall, visible over three stories can have in each story other openings. The markers of the openings return always the home story of the wall."
Maybe there are more bugs in this ambient. Just keep a focus on this and try it in further versions. Just a hint.
Ben Cohen
Try "ac_glob_elevation - length
elevation of the base line of the opening"
Found here
http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/14/LibDevGuid...
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
Thank you all for your replies!
Ben: ac_glob_elevation only tells me the height of the window sill from the wall bottom. I get that working all right.
F_beister: my windows are in the home story of the walls so your bug does not affect my case. Anyhow I got the window marker to read the elevation of the home story all right. The problem is, my window marker cannot seem to get hold of the measurement from the story base level to the wall bottom level.
Master script: I tried your suggestion, with the result that it always returns +0.000. Apparently these variables are not available to a window marker?
If anyone still has the patience to make any suggestions, they are more than welcome! It may also be that there is some stupid mistake in my code, my GDL skill is mostly limited to tweaking existing objects so I don't always quite understand everything that's going on there.
