Window looks in different color
eneskaraca
I created a window style, to create new window I copy the window parameters from previous with alt click and insert the new wall. But here is the thing it changed the color. I move side by side the two window as you can see the original one (upper) is darker color but other has lighter black color. I checked all the color settings but they are same. I couldnt figure out can you help about that?
1 REPLY 1
eneskaraca
I realize all objects has this color difference issue, I dont know how but I need the fix that urgently
Setup info provided by author
