Window plaster turn
Hi guys 2nd doubt today
I'm trying to create interior openings (and sliding doors). I'm trying to make my doors 90 cm wide (the opening) and than I say I want to turn the plaster to make the wall ending on each side of the window correct but when I do so the door becomes 85 (2.5 cm of plaster on each side). Is there a way to make the plaster turn always outside the 90 cm I defined. I know I can make a door of 95 and than the openning would be correct but if I than use Listings the openings won't be correct.
In the image is the version bellow that I want to recreate:
sinceV6
Hi.
Check the "nominal sizes and tolerance" page of the door settings dialog, and use one of those. You could use the "unit" dimensions as nominal and then add plaster size to tolerance (your wallhole size will read 95cm, but the door will list -depending on your settings- as 90cm).
Best regards.
Tanks for answering, I will try your solution!
Kind regards
