I have one window that won't close in my model. It is set to 0", all my settings say it should be closed. I can delete it, place a new window, eye dropper it...no matter what it is open. I've changed the settings to open then back to closed. No change. Restarted Archicad, no change. All my other windows are fine. On the elevations you can see the brick behind it. Any ideas??
**EDIT** it is closed, the bottom pieces of glass are just not showing as blue. The materials are set correctly, I'm not sure how to fix it?
Archicad24
Mac
Designer
Mac
Archicad 26
