sma2bim
Windows - Door | Balcony Insulation reveal
Hello ,
I need  some help. I am working in project where we have doors/windows opening in terraces and balcony.
Windows objects and doors aren't correct in section.
I don't know if it is possible to get a result like the picture (not as detailled but at least with right ccompenents )
thanks
[ BIM Manager- Revit Expert
Win 11 - Dell Precsion i7 | 32GB | RTX A4000
AC25 - AC26 4019 Int Full]
2 Replies 2
Lee Hankins
It wouldn’t be part of the window/door itself but you could set the window/door with an enlarged opening and then use a complex profile applied to a beam to create what you see in your detail.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
sma2bim
I will give it a shoot.
thanks
