Llian
Windows- One unit with 4 sections
I noticed the window library objects have up to 3 sections - I need one unit that has 3 fixed and one openable casement window. How do I do that?
Thanks
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
4 Replies 4
Can't you gang two double casements? (Actually, one of the double casements would be a W Casement 1 window without the transom, to get the fixed/operable effect. See help menu on ganging windows.)
Richard
AC26 (since AC6.0), Win10
Llian
Thanks Richard. I see that but I need to have one marker for the multiple sections to represent it as one unit. The gang still have separate marker. I did a long way but look like it works for now by having one opening of that size and draw the rest in 2d....<sigh>
Okay, then maybe use the Ribbon Window (all fixed), but add some 2D linework for the operable sash, and a note in the window schedule.
Richard
vistasp
If you're on subscription, try the Modular Joinery Object from BIMcomponents. It might work for you.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
