So many questions about the windows, and casings and shutters........
The window on the left is a W1 Casement 12 window from the library with shutters as selected in the parameters. The window on the right is the same window without shutters, and I've drawn shutters on the elevation with fills and lines.
1. Why, in a stud-wall-with-siding reveal situation (window setting), does the window casing overlap the sash and frame? Is there a dimensional parameter to fix it? The dimensions in the casing settings appear to not locate the casing in front of the window...?
2. Why are the shutters applied to the library window inappropriately located on the window casing? How do I manipulate the casing (or other) settings to show the shutters like I've drawn them on window #3? And, what's up with that sill/casing situation on the bottom?
3. This is apparently an extension of part two of question 2, ie, why does the casing descend below the sill? Is this fixable?
I feel like I've explored the window settings exhaustively attempting to fix these things..... Do I just need to get that additional window application? Would it fix everything I'm asking about? Is it worth it? I just feel like I'm not understanding something when I need to draw opaque boxes over things to "fix" them.
Thanks y'all...
