Windows - sill nosing thickness
I am looking for a window which I can control it's sill thickness
independently, with no connection to any other parameter.
Does anyone knows where can I get such a window ?
14 Replies 14
We'll tell you when you use an authentic username to identify yourself. 'anybod' sounds like a spam merchant. what are you so ashamed of?
Dwight
Beat the guy up already.
Shame on you.
Dwight Atkinson
Jacek
Ouch!
Relax ......DELETED..................................instead....
david wrote:
Deleted by moderator
Jacek, english as ................. language
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
Djordje
anybod wrote:
I am looking for a window which I can control it's sill thickness independently, with no connection to any other parameter. Does anyone knows where can I get such a window ?
You could try Theometric Window Builder at http://www.theometric.com.
But - how can a sill thickness NOT affect the other parameters? Think about it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje
Jacek wrote:
Ouch!
Relax a bit, have a pint. Capitalize after a period. Perhaps you should answer in Hebrew instead....
Jacek, english as a fourth language
HOLD IT RIGHT THERE!
Please refer to Etiquette.
1. usernames should be your real names; if they are not, then inculde a full signature or ask the Administrator to change your username
2. personal attacks are NOT allowed
If someone cannot find the Etiquette link on top of the screen, here it is:
http://archicad-talk.graphisoft.com/etiquette.html
Now relax and enjoy the holidays!
Djordje
HP Omen
David,
I was very surprised to get such an angry response for my username, cause this is the username I use alot in the internet and nobody ever seemed to have a problem with it. No, I have nothing to be ashamed of, it is just a matter of privecy, a habit, that's all. Anyway I've already asked the administrator to change it to my real name: Nice to meet you, I am Shira.
Well I did try the link but it was broken.
Why do I need an independent sill ?
Well that's because I use a sill board made of a completely different material , for example stone, so I need it in different thicknesses. In all Archicad Library windows, the sill thikness is half time the dimension of the frame thickness or less but never more. And what if the frame thickness is 5cm Aluminum and the sill nosing is 5cm stone ?
Thanks, Shira
Djordje
My bad - the right URL is http://www.theometric.co.nz
Yes, you do have a point for the sills. Maybe a wish in the wishlist forum would not be a bad idea?
Djordje
HP Omen
