2004-06-03
04:41 PM
2023-05-24
12:50 PM
Rubia Torres
2004-06-03 05:11 PM
2004-06-03 05:43 PM
2004-06-03 07:08 PM
2004-06-04 12:04 PM
Michele wrote:Hi Michele,
I want to put a curved roof on a building & then put a window in with multiple vertical & horizontal mullions that will match the curve of the roof. The wall is vertical and only curves to meet the roof. It does not curve in plan. Is there an object out there that will do this? I checked at objects online and I only saw one window object that looked like it had a straight flat top to it and not the arched or curved top I'm looking for. Does what I need exist in an object or would I just make a window out of walls and trim to roof??
Any suggestions would be great.
Thanks,
Michele
2004-06-04 12:10 PM
ILet's try that again !
Included is a view of the finished product in an unfinished model
HTH
Naftali
2004-06-04 12:53 PM
2004-06-10 06:58 AM
Michele wrote:Fastwindow will create an arch - available at Objects Online. So simple you will not ned any help to do it.
I want to put a curved roof on a building & then put a window in with multiple vertical & horizontal mullions that will match the curve of the roof....
Thanks,
Michele
2004-06-10 03:17 PM
