2005-12-09
09:09 AM
2023-05-24
09:43 AM
Rubia Torres
2005-12-09 03:47 PM
2006-07-20 02:38 PM
2006-08-06 12:03 PM
2021-10-19 09:25 AM
Can we get the wood and glass quantities now i.e in AC19 or AC 24
2021-10-19 10:13 AM
No I don't think so.
As mentioned in the replies of one of your other posts (https://community.graphisoft.com/t5/Document-Visualize-forum/Window-section-detail/m-p/309055/highli...), the door and window objects that come with Archicad, just aren't that detailed and don't contain quantity information for manufacturing the frames.
You could maybe get some very approximate quantities using properties with expressions using the width of the window x number of horizontal members and height x number of vertical members for lengths and then multiply that by frame dimensions to get a volume.
But it would be very messy and I wouldn't want to rely on it.
To get accurate quantities, your frames would need to be modelled as complex profile beams or walls.
As in physically modelled exactly as you would want to build it.
Or you would need to script objects that can report the values for each member used in the frame.
