Jackcowdrey
World Coordinate Point
Hi all,
I am trying to add a world coordinate point in my model, to reference in some survey plans. I am using Archicad 22.
I am trying to place in the object 'World Coordinate Dimensions'. Once I select the object then click in the model it creates a point with the associated world coordinates. However, what I want to do is the reverse: enter the world coordinates to give me a point. Can anyone please tell me how to do this? I can't figure it out for the life of me!
Thanks
5 Replies 5
Hello Jackcowdrey,
You can input these coordinates here :
Option/Project Préférences/Location Settings
To understand how it works :
https://helpcenter.graphisoft.com/user-guide/127874/
IFC BIM model include geodesic coordinates.
To export these geodesic coordinates into an IFC model you have to check your IFC translator before.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Jackcowdrey
Thank you for your response however changing the project location is not what I meant.
I already have the project location set up, what I want to do is create a new point in the model by entering in the world coordinates. Surely there must be a simple way to do this?!
This is a curious issue because when I check the Object, I can see that there are fields for this among the settings but they are grayed:
I think these are the fields that you are looking for. And I suppose the way it should work is you set the coordinates here and no matter where you click, the Object is placed at the specified coordinates.
Minh Nguyen
Hi Laci,
Thank you very much for bringing it to our attention!
We have investigated the object and concluded that those disabled parameters were a bug. We registered it as DEF-4677. I hope that it won't be a difficult one to fix.
Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
njal
Hi
Use Coordinate Dimension 16 in order to place the object based on Lat/Lng.
