Wrong origin when stealing into 2D Script window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2017-03-13
06:47 PM
‎2023-05-24
12:29 PM
Rubia Torres
I place a hotspot on the origin (which I swear it is, the rulers show 0,0, etc.) in floor plan view. I drag it into the floating 2D Script window and get this:
pen 1
hotspot2 -127366.2544831, -121862.270517
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-13 06:59 PM
Yes it is the "problem" (I would call a bug) with snapping to a point accuracy.
If You want to be sure about 0,0...just have to move the object using the typed in coords.
Best Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-13 07:22 PM
I tried with the hotspot placed at 1,1 and get
hotspot2 -127365.2544831, -121861.270517
which is coherent with the previous 0,0 as
I had been using this method for ages.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 01:14 AM
Double click the origin button to reset the user origin and see if it moves.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 02:40 AM
Barry wrote:It is the real origin. You get used to doing stuff around the model origin when you want to steal into the script. And I am not sure that I could work ~170 km away from the origin even if I wanted to.
Maybe your origin is a 'user' origin rather than the 'drawing' origin.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 03:11 AM
Ignacio wrote:Are you really sure it is not a user origin?
The rulers will still say 0,0 for a user origin.
The reason I ask is because this is the code I get if I place one hotspot at the drawing origin and another at a user origin and drag (steal) them into the 2D script.
pen 11 hotspot2 20.86856641983, 9.470493196231 !!hotspot at user origin pen 11 hotspot2 -0, -0 !!hotspot at drawing originBarry.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 03:20 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 03:51 AM
Ignacio wrote:No the user origin is simply a user positioned origin.
I know what a user origin is. It is the model origin.
It can be anywhere you choose and will be referred to as your 0,0 co-ordinates.
So you may well model around this user origin as if it is 0,0 (I guess what you are calling the model origin).
See attached image.
What you are looking for is the default origin.
I called it the drawing origin - its correct name is the 'Project' origin.
This can not be moved.
Please indulge me for a moment and try this.
From your hotspot (origin) that you are seeing as 0,0 in plan, move your cursor so you can see the co-ordinates +127366.2544831, +121862.270517
This is the exact opposite of your saved hotspot script.
Do you see a greyed out origin there?
If so that is the project origin that you need to use if you are expecting to get 0,0 for your hotspot when dragging it into the script.
Or just double click the 'Set user origin' button and see if the origin moves.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 04:23 AM
and I replied
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2017-03-14 04:39 AM
Ignacio wrote:Hey, I'm just trying to help.
Barry: you asked
and I replied
What I am saying is the model (user) origin is not what you want.
To get the 0,0 co-ordinates you must use the Project origin.
I am 99% sure you are not using the project origin - but I could be wrong.
Have you double clicked the set user origin button to see if it resets the origin position?
If it doesn't then I am out of ideas.
