Zone Stamp GS ITA - Timbro Zona GS ITA
alegafs_92
Hi everyone,
I think I found a little problem in the Archiclub Zone Stamp GSITA object. I'm using Archicad 28 and I've imported the Archiclub Library for v27.
I wanted to use the GS ITA Zone Stamp in order to automatically calculate the RAI for every zone.
The problem is that the RAI is moltiplicated by 100 when I set centimeters as unit for linear dimensions.
I make an example to be clear:
Zone Surface = 7.40 m2; Window Surface = 1.89 m2 ---> RAI (WS / ZS) should be 1.89/7.4 = 0.26 but in the table I get 26
If I set the unit dimensions to meters it works correctly so I'm quiet sure it could be the problem.
It will be corrected in the future? Thanks
0 REPLIES 0
Setup info provided by author
