Scott Bulmer
Zone Stamp - wrong measured area
Greetings all, using the Masterzone (formerly known as Superzone-2), the Measured Area calculated value is incorrect. In the attached screenshot you can see the Measured Net Area is 221 SF, however the Measured Area returns an incorrect value of 6,000 SF. Any ideas will be greatly appreciated.
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
2 Replies 2
At first glance, 221 sq ft looks small, but 6000 sq ft looks big. did you run an update zone?
Scott Bulmer
Michael, yes on the update zones. I just now fixed the issue which is that there was a nearly unperceivable gap in the enclosing walls. When properly joined this issue went away. Thanks for you response. Scott
