2008-03-11
08:58 PM
2023-05-24
12:02 PM
Rubia Torres
2008-03-11 10:11 PM
Geof wrote:ArchiROTATE
Or is there a way to save it on the flat, then tilting the whole thing 45° without getting into too much script?
2008-03-11 10:41 PM
Geof wrote:If you don't have ArchiRotate and want to create your object without
I'm trying to model this solar collector, angled at 45°.
I built it on the flat, going to 3D to click on view from top, and then adjusting the angle in the 3D window so it'd be saved at 45°. But of course that knocked it out of "top view". Is there a way to save it at an angle?
2008-03-11 11:03 PM
Geof wrote:OBJECTiVE will do this very well. Simply select the object, click the OBJECTiVE/Rotate menu, set the rotation axis and angle (much as you would do for 2D rotation), and that's it. The rotated object will display with hotspots in 2D and 3D for easy snapping. and you can also use OBJECTiVEs Split tool if you want to cut portions off.
2008-03-11 11:45 PM
Stig wrote:Poetically simple!
If you don't have ArchiRotate and want to create your object withoutanyscript you can do a double save:
First save your model looking at it from the side and then place the resulting object on its edge in the plan view and save it again from the desired angle.
Stig
Ralph wrote:Hmm... I
2008-03-12 05:23 PM
Geof wrote:That Baby is full grown now
....... that baby.
2008-03-12 06:40 PM
