2004-10-27 12:08 AM
2004-10-27 07:38 AM
2004-10-27 10:20 AM
2004-10-28 12:47 AM
2004-10-28 05:15 AM
Geoff wrote:Dear Geoff,
I’m hoping someone familiar with AppleScript can help me modify a little script I uncovered from the AC7 days that enables OS X users to launch multiple AC sessions. It was written as a TeamWork fix but works even now with AC9. With some tweaking I think it could become the preferred way to open multiple projects.
2004-10-28 05:59 AM
Geoff wrote:i'm still not actually seeing the benefit . . . is it purely to save hard disk space so that you don't have to copy the app file again and again? (remember that it is only the application file itself that needs copying into the same application folder). i would actually say that it's safer to copy the application and rename it ("archiCAD TWO", or something) because then it's definitely given separate processing threads from the other and there's far less chance of something going wrong . . . (not that i actually know much about that kind of stuff
Yes, I was hoping the script could be modified such that every time you ran it you'd get another AC session. Currently you have to copy and rename the script for each session, but clearly OS X supports multiple sessions, at least the Unix core does. I'm hoping that the right person can rewrite the script for the general benefit of all OS X users.
2004-10-28 05:21 PM
2004-10-30 04:42 PM
Geoff wrote:I wouldn't call myself a 'guru', but I've written a number of tools with AppleScript. I can take a look at the problem if you send the script to me with a description of functionality you're looking for.
Are there any AppleScript gurus out there?
2004-10-30 08:10 PM
