archicad 14- trouble with libraries
hey i have just recently updated to archicad 14 on my intel mac. however, when i go to use the window, door, or object tool there is nothing loaded. does someone know what i should do?
21 Replies 21
Marton Kiss
The first hotfix for ArchiCAD 14 have been already released for some language versions and will come to the others soon. That fixes the Local Data Manager's bug, and also the error that Trevor had.
When some libraries are missing check how do you access the BIM Server: if the server has a valid DNS name use that, not only when joining the project but when adding libraries too.
If you have a library which elements seems to be missing: delete the library from library manager and add it again by using the DNS name of the server.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Greg Kmethy
Dear all,
If you are experiencing the Library problem on Mac, please follow these steps:
http://archicadwiki.com/Bugs/Teamwork/LibraryNotFound
Hopefully this will resolve the issue.
Gergely Kmethy
VP, Customer Success, Graphisoft
