‎2004-06-09 02:16 AM
‎2004-06-09 03:02 PM
‎2004-06-11 08:13 PM
Jefferson wrote:It looks like some of the lines are not exactly joined or overlap just so; you can do a few things:
All simple enough for me and it usually works. I have attached a screen shot showing that when i attempt to place the object I get this error message [which if I check stop allows me to continue]and some missing lines. Further when I select it selection dots indicate that the missing lines are there.
‎2004-06-11 08:54 PM
It looks like some of the lines are not exactly joined or overlap just so; you can do a few things:-
move the stuff closer to the originLiterally the project origin?
do a Check duplicates - usually dozens in a DXFcan do..............
- check whether the lines really join at corners (use chamfer and/or Intersect from the Line extras)You are refereing to an action I referred to in my first question?
