corrugated metal deck
Has anyone made or found a library part for a corrugated metal deck?
5 REPLIES 5
Dwight
If there isn't, you can always make it with the complex profile....
Dwight Atkinson
vfrontiers
If the "plan" of the deck is complex, I have been using ROOF SURFACER...
1. Place Roof at 0deg pitch
2. Run Roof Surfacer (ACCESSORIES, you have to add as a GOODY)
3. Choose CORRUGATED DECK profile
4. Set profile such that the bottom of the deck matches the bottom of the roof
5. Use SEO's to remove the portion of the ROOF that is BELOW the deck
6. Give the ROOF a CONCRETE section fill
If you don't want the concrete on top, you may have to do steps 1-4, then...
5. PASTE A COPY of the roof surfacer (deck) and delete the original and the roof. If they stay connected, deleting the roof "may" delete the surfacer also.
HTH,
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers
HTH,
Duane
Visual Frontiers
where do you get "roof surfacer"?
Erika Epstein
Design>Design Extras >Accessories>Roof Accessories
Missing Goodies? Go to your HELP menu in archicad and download them.
Follow Duane's instructions.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
