‎2017-01-2206:29 AM - last edited on ‎2023-05-2412:29 PM by Rubia Torres
‎2017-01-2206:29 AM
I need to change the door and window marker's, there is an option under settings that says load other door marker, what format should it be for it to work? I need ovals for doors and hexagons for windows.
iMac - MacOs Big Sur 11.6.6 Archicad 24 - Latest Build Archicad 25 - Latest Build
They are library parts of the Window-Door-Skylight Marker Subtype, so if they are in the loaded libraries would show up as options in the pop-up list. You could also Label the Doors and Windows instead using a Dimension Marker.
David
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
