custom door panels come in too small
hi, have you guys made any custom door panels yet in 13?
I did, and when i put it in my model they show up too small.
22 Replies 22
laszlonagy wrote:
Pasted from another thread:
The type of Custom Components you can save will depend on the loaded libraries.
For example, under Windows, the C:\Program Files\Graphisoft\ArchiCAD 13 INT\ArchiCAD Library 13\Custom Object Macros 13 is the place that contains the subtypes defining the types of Custom Components that can be saved. This has to be loaded for them to appear as options - of course they do if you just simply load the ArchiCAD 13 Library.
So you need to load that library for the options to appear.
That is loaded.... Not sure what I'm doing wrong...
Is this what you are doing?
See attached image.
See attached image.
Yep. I tried Custom Door Panel and Custom Door Leaf.
So then to use this I would go pick a door like D1 Entrance 13 and pick the custom door panel then my custom door should show up in the pull down menu, right?
I just opened a fresh plan file and it worked fine.... I guess it is a problem with the file I'm working in.... I may archive and reopen it to try to fix the problem...
thanks for your help
Glad you finally managed to make it work.
Strange stuff though, I recall that others had this same problem with these Custom Component. Will let GS know about it.
Yes strange..
So I did notice in the fresh project that I only had the option of saving the slab as a "Custom Door Leaf" while in my original project I also had the option of "Custom Door Panel".
For what it is worth it seems to be working now. I archived the file and reopened it and now it seems to work...
Erika Epstein
Steve,
You need to open the cusom door panel part you created. In AC13 the default is that custom libaray parts will become embedded in the file.
File>Libraries & Objects> Open Object>Embedded Library> [the door you just created]
From the [the door you just created] window that opens, see my attached screenshots, click on theh Select Subtype and choose Custom Door Leaf.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
select subtype
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika wrote:
Steve,
As it turned out it isn't that I didn't know how to make and use the door, I had a corrupted plan file... it is all fixed now
thanks
