2009-10-23
05:24 PM
2023-05-24
10:56 AM
Rubia Torres
2009-11-19 09:18 PM
2009-11-19 09:42 PM
laszlonagy wrote:I likely did have both of those libraries loaded. I did switch from 12 to 13 near the beginning of the project. I suspected it was something like what you describe. So adding to the possibilities I also had the AC11 migration library loaded because I had so many problems with AC12 doors in general...
Steve,
In AC13 there is no "Custom Door Panel" option. There is only "Custom Door Leaf" option.
But in AC12 there is "Custom Door Panel" option.
So the same thing is called differently in the two versions.
So I am thinking maybe you had both AC12 and AC13 libraries loaded and the subtypes got mixed up somehow.
When you save as Archive, only one was saved - this may be why it worked after reopening the PLA: there was no two versions anymore to get mixed up.
2010-03-11 03:52 PM
