Learn more
dimension marks for doors
Hello.
I work with a lot of doors now on a 1:100 plan, which requires the text to be quite large in comparison to the doors. I am trying to make things easily read. That is why I would need the 2 dimensions of a door to be more close together and closer to the mid line. I found no such setting in the dimension marker settings. Have I missed anything?
Thank you.
11 Replies 11
Frank Beister
So if you understand a bit of German you will understand broken English too. 😉 I have uploaded a tiny video on openGDL, which shows, what I have described above.
The objects do not destroy your ArchiCAD or project. They just add new objects to your library.
Now I managed to change the space in between the lines. Thank you very much for all the help.
