display order with doors
Hello.
I currently have two doors that intersect. I would like the display order to be different, namely the left one to be on top of the right one, so that the marker does not cover the left door.
How can I do that?
Thank you.
Stress Co_
Select the wall which has the door you want on top and Edit> Display> bring forward.
I'd just adjust the location of the bubbles.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Good idea. I just adjusted the bubbles. Thank you.
