Gus
door sched. door thickness listing problem?
the door schedule is showing the door thickness as 1 1/2" but its a 1 3/8 door. Even when i click on the thickness dimension in the schedule it shows up as 1 3/8 then it jumps back to 1 1/2" What's going on? How do I get it to list the door as it actually is?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W [email protected]
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
5 Replies 5
Have you checked the precision of calculation units in the preferences?
Gus
I checked some precision preferences for the project as a whole. Which preferences are you thinking of?
Madison WI
OPTIONS menu > PROJECT PREFERENCES > CALCULATION UNITS.
David Maudlin
Gus:
Once the schedule is made a View, it has View settings similar to a plan or elevation. With the schedule selected in the View map, click on Settings, here you will be able to set a Dimensions preference. The Dimension preferences are set up under Project Preferences > Dimensions.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Gus
Got it. Everything is back to normal again, the sun has come out, and I can continue with my life as planned. Thank you so much.
Madison WI
