2009-04-22
10:59 PM
2023-05-26
11:27 AM
Rubia Torres
2009-04-23 11:45 AM
2009-04-23 12:35 PM
lpbolden wrote:select CW>edit in 3D. Select door panel and go to its settings, under options> opening direction will change door swing from outside to inside and vise versa. Opening type will change door swing from left to right (and vise versa)
how dow you change the door swing in the curtain wall? I saw the label for inside and outside. How to i change what side it swings on. The only I could do was change the direction of the door (top and bottom)
2009-04-23 12:44 PM
2009-04-23 01:10 PM
rocorona wrote:sorry, what?
Yes, I saw that, but it ALSO changes in what side of the CW the door opens, so I discarded this option.
I think here we are discussing on simply swatch the sides right/left, so wich hand you use when PULLING the door to enter.
2009-04-23 02:21 PM
2009-04-23 02:42 PM
