door whitout any frame
hi dear
what is the best way to create glass doors Without any frame?
4 Replies 4
If you mean like a shower screen door then you could use an actual object for a shower screen or you could use a thin wall with glass material assigned to it.
rgarand
I use the Commercial door and select the glass door option and place it within a 1" thick glass wall.
See Screenshot
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
rgarand
By the way,
The door frames are set to 1/8" all around
Robert J. Garand
THANK a lot ,I had very good answer
