2007-03-20 10:36 AM
2007-03-20 03:14 PM
2007-03-20 11:29 PM
rakesh.shingre wrote:
hi
i am facing a problem in duplicate libraries while shifting to AC10 from AC9 ...can anyone suggest me the correct method to load the libraries....without having duplicate lib error..
2007-03-21 01:28 AM
2007-03-21 07:42 AM
2007-03-21 07:51 AM
hi
the same type of library loading error (000000000) is coming if i directly open the AC9.pla file in AC10......is there is any problem due to archive file of AC9...
I have save the project in AC9 .pla extension due to some of custom textures and GDLs use in that project.....
2007-03-21 07:53 AM
2007-03-22 12:51 PM
Srinivas wrote:The library loading report can be quite useful as it identifies precisely which parts are missing or duplicated (you have to expand the hierarchy to see them of course), but with so many (1360) it seems that you have entire duplicate libraries loading. For this check the library manager.hi
You need to extract the Pla file into a folder( when you open the pla in version 9/10 it will display a dialog box which gives you an option to extract the library used) and then add the Custom Texture and the custom GSM's to the Library Manager to avoid this problem.
Please see the Libary Manager screen shot is not posted, the screen shot posted is Library report which is of little use.
2007-03-23 08:02 PM
