editing GDL in 3D window
how to edit GDL gsm component in 3D window? or is there alternatives, how to easy edit component, similar as in sketchup?
David Maudlin
girts:
The Object can be converted to Morph, then edited in the 3D Window, but this will loose the parametric features of the Object. A parametric Object needs to be scripted, not edited in a 2D or 3D window.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
ok, Morph is not what I need, unfortunately
/thanks
David Maudlin
girts:
If you post a description of what you are trying to accomplish, preferably with screen shots, someone may have some alternative approaches to the problem.
Thanks for adding the signature.
