ā2007-02-23 03:25 PM
ā2007-02-27 01:24 PM
ā2007-02-27 03:04 PM
ā2007-02-27 03:54 PM
David wrote:The problem with the revolve is that it will produce a circular arc rather than the catenary (parabolic) curve which will look wrong even to a casual observer. Of course it means breaking out the old geometry texts for the formula and sorting out how to put the values into a tube statement, which is fairly advanced GDL programming.
If you decide to tackle it, I would probably start with the Revolve command, define the profile of the wire itself, then calculate the sweep angle based on the distance to cross and the amount you want the line to droop.
ā2007-03-01 04:07 PM
