external txt file generating hotspots
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-07-08 12:37 AM
I am working with a built-as registration of a huge and complex building.
I have a Leica Builder R200M Theodolite to generate surveyor points.
I can export from the Builder to a dxf file which then can be imported in my *.pln as an object.
My idea is to make a more floating process where the theodolite writes a text or ascii file which is linked to from a gdl object and then generating hotspots i 3D.
Some years ago in 6.5 I did something like this which actually was a spreadsheet saved as a textfile and then imported to a prism. I think I used the OPEN & INPUT command which seems no longer to have the same functionality in AC12 , or?
Any ideas
Nicolaj Hvid
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-08 01:02 PM
you can use architerra for this - even the trial version lets you import a text file - tab delimited , csv and it puts hotspots on plan and gdl object with options on display style etc.
we have a totalstation which gives me the data which i adjust in excell and save in tab delimited.
i added to the gdl object to give a 3d display of points - handy when wanting to view the points in sections.
hope this helps.
Mark
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-08 10:24 PM
I tried your solution before my post, but it seems that you are equipped with more luck than I am.
I can see the txt document contains all 4 rows but I'm only getting the xy on the floor plan.
The idea about getting an object with ID, x, y and z value marked as a kind of 3D hotspot is what I'm aiming at but how?
I'm working on a trial version ArchiTerra 3 on ArchiCAD 12
Nicolaj
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-09 12:45 PM
most of the other functions are disabled but you can show the spot heights where you can show on the plan the x y and height values.
once you do select the xy labels - they are actually generated by an object developed by architerra. if you open this object up you can click the show 3d parameter on.
this will show a pretty crude 3d marker - there are parameters that you can adjust this to suit but you can also open up the object and modify it to suit you.
Mark
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-09 05:27 PM
I do not see any xy labels. Neither do I see the heights in the
So now I wonder:
Is there something wrong with my textfile or is there a limitation in Architerra.?
If I open the textfile in WORD it opens with all 4 columns.
Nicolaj
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-10 02:46 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-10 04:42 PM
basically tho just tab delimited text files xyz code
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-10 04:42 PM
pic shows architerra toolbox with functions used and resulting 2d hotspots with markers showing height and code, in background.
we use a topcon gpt3007 i think is the model.
we have only done very simple surveys with it so far but works well - older model but robust
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-30 08:51 PM
Unfortunately this cannot be done straightforward on archicad and my knowledge on GDL cannot go further, as my job is an architect and not a software developer. In fact, archicad lacks of critical functions in importing and exporting data for total stations. As an example, after having designed a nice house on archicad it needs to be traced on the terrain. There is not any function on archicad for exporting a txt of xls file with point names and their 3d coordinates. I have tried many different solutions with 3d objects but none of them is practical in terms of real-world construction. At the end, after 12 years of using archicad I tend to think that it is an excelent design tool but it lacks of professional tools for building the projects. ...and there comes autocad, which is a nightmare but it is for building. And at the end of the day this is our job!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-10-30 08:56 PM
