generic perspective (3D) not working
Some how, when I asv to see all in 3D, I can't see nothing with Generic Perspective, but Generic Axonometry, it works. All starts when i clicked Fit in Window couple times by accident. In my lefte bottom corner appears the following message "Enter First Node of Wall". Does anybody have a tip.
I'm using Vista. I tried on XP but it doesn't work eigther, however, if i open a different drawing, it work fine in both systems.
You are probably just looking away from your model.
Try going to 3D projection settings, placing your camera (SHIFT-click) and target (ALT-click) and making sure your camera Z and target Z are similar (i.e. not looking to high up or low down)
Thank you! Problem solved.
