getting wall opening to match non rectangular window gsms
When I make a custom window with a non-rectangular form (say an arched top) and use it in a wall, the opening that ArchiCAD makes does not match the outline of the window. Is there a setting that controls this?
4 Replies 4
Thomas Holm
Do a Search for Wallhole.
Ha! Works perfect.
Make a slab that defines the rough opening of the window object and change its ID to 'Wallhole,' then save it with the rest of the window object.
Does the depth of the slab matter for 'Wallholes'?
Thomas Holm
There are some niche objects among your windows in the default library. Check them out (open and check scripts) to see how depth is defined.
Djordje
No. It is hole, right?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
