Windows missing detail in plan view
Can anyone help? I have recently updated to v 11 and I have a problem that when I insert a window in plan view non of the detail appears. The window is essentially blank. Sometimes no frame or glazing lines appear.... It is less than convenient and I can see any settings in the parameters that would affect it...
Help anyone? Ta!
14 Replies 14
Did you check your Model View Option settings?
Karl
Model view settings are fine. but still only an empty window... Most frustrating...
Is the Floor Plan View of the window set to Symbolic?
Yes it is set to symbolic, I haven't changed it but now it seems to be working. How bizarre! Thank you!
My work mate has the same problem and has done everything I have done thus far. Any more suggestions?
What window object are you using?
She has tried several window objects with all the same problem. (No detail, no frame, no glazing etc) As a temporary measure she has changed the properties of the window to be "projected" rather than "symbolic".
Floor plan cut plane set to just catch the bottom part of window materials?
Leaving out rest of window materials/details?
Bier
Link
Did you try them at different floor plan scales?
Link.
