‎2008-09-04
02:53 AM
- last edited on
‎2023-05-24
12:42 PM
by
Rubia Torres
‎2008-09-04 08:01 AM
‎2008-09-04 08:10 AM
‎2008-09-04 08:29 AM
kirst.coultas wrote:If projected works and Symbolic doesn't then I would be suspecting something wrong with the 2D script or a parameter setting that affects the 2D view.
She has tried several window objects with all the same problem. (No detail, no frame, no glazing etc) As a temporary measure she has changed the properties of the window to be "projected" rather than "symbolic".
‎2008-09-04 08:39 AM
‎2008-09-05 12:07 PM
kirst.coultas wrote:You sure it is not in the RCP mode? Sounds very much like it ...
Model view settings are fine. but still only an empty window... Most frustrating...
